Where is the earth for the horn?
9 May 2013
Cornwall
So my horn is intermittent at best. Press it and no sound most of the time, but then every now and again it gives a little bip after a few tries.
I'm assuming a dodgy earth, so whereabouts is it?
Or any other suggestions are welcome if anyone has come across this before.
Kind of important as there's plenty of idiots round here who need beeping at!
21 July 2011
England
Usually contacts on back of horn / air bag just need cleaning up
9 May 2013
Cornwall
Ok cool ill give that a check tomorrow, cheers
Also make sure the connections are clean on the actual horn. (In front of rad)
9 May 2013
Cornwall
It was the earth connection. The spade connector had broken off the wire and some genius had just exposed more wire and wrapped it around the connector on the horn, which had corroded. :wack:
stanletmontena
I think there must be a loose connection and not earthing problem. Try checking the wires that are connected to the horn. Hope it helps.
9 May 2013
Cornwall
Sorted already dude!
