Nissan S15 sputters / hesitates during full throttle
5 March 2015
Sweden
Make a short story of this.
Ran the car home to give it a wash. 1.5h later and good to go I noticed it started to sputter / hesitate during full throttle :confused:
Now I been tried to fix this issue by change;
Brand new plugs, bkr7e re-gapped to 0.7
New fuel pump (from nissan r34 gtr)
Coil pack
All vacum lines
Blocked BOV (if that made difference)
Added a ground kit
None of these helped at all.
If turning off the boost controller to run stock boost at 0.7bar it runs fine, but turning up boost it start doing this funky sh*t again. Car have been tuned with apexi PFC incl the EBC set to 1bar / 14.x psi.
By looking at the new plugs, 2of em are very white. So now im gonna go for a new fuel filter and try another set of injectors and MAF.
Did any of you had similiar problem?
Please help, running out of ideas :annoyed:
Video;
Jaydej
6 December 2013
Herts
Sounds like your losing ignition when it comes on boost
5 March 2015
Sweden
Any tip on what to check next?
Any help appreciated!
5 March 2015
Sweden
Plugs are brand new, gapped to .028 / 0.7
I hope its not the coils. They are only like 10.000km old (Yellowjacket)
What about the the plugs are white at the tip? My old ones arent :|
sibbers
11 February 2015
Twickenham
Coil pack mate!
or plugs one or the other! mine was dodgy no.1 pack.
Another vote for coilpack
Great vid btw, should help others that search out the problem. Usually happens worse when cold and car under greater load.
White at the tips usually means lean/no fuel. Got any pictures of the plugs? Injector issue? Over boosting?
Also I run bcpr7es gapped to 0.7 although I've read bk's do fit but aren't as tall.
5 March 2015
Sweden
Thanks for all the tips.
Turned out to be the coil-pack.
Looking for another set of coil pack. Do you guys have any tip here?
Wont be using YJ coils again. But what about splitfire?
Thanks again!
Mycool
3 January 2014
Gloucester
@S15_wot
i had this problem, couldnt get round to what it was, it ended up being the coilpack harness!
