New here
12 September 2016
Auckland
Hi everyone in new here just got a s15 today I'm from New Zealand
would like to get help and advise cheers
will post photo of car also 🙃
Joeh
12 December 2006
www.silivaoc.com
@silviaownersclub
When you chose a sharing link from Postimage, use the "Hotlink for forums" option, I've edited your posts to fix the images
12 September 2016
Auckland
To be honest I'm not sure would like to find out,only got the car today
Joeh
12 December 2006
www.silivaoc.com
@silviaownersclub
Upload a picture from inside the boot, usually that is the biggest give away. (take a picture close to the rear panel where the lights are)
The inlet manifold and cam cover design is not from S15 Spec R but it might have just had a replacement engine or someone was experimenting.
12 September 2016
Auckland
how can I tell if it has a link g4 ecu says it does I've had a look but unsure really
Not the original motor. The black top SR20's in the S15 didn't have a distributor. I would guess the motor is an S13 red top
That was originally an NA...look at the inlet runners and distributor. It's had the turbo added...what boost is it running ?
Joeh
12 December 2006
www.silivaoc.com
@silviaownersclub
I was thinking that however one key factor is that the inlet manifold that it's running is something that was only on older S bodies, so I was considering the possibility that it could be a forged engine from another model that's just been transplanted in with the large turbo.
12 September 2016
Auckland
Found out a little more info this morning
Body is a Spec-S with 103,000K's with a SR20DET swap with motor around 32,000K's
Everything is Certed & Have Just Put on WOF & REG
- SR20DET (32,000K's)
- Link G4
- 5-Speed Manual Transmission
- 6 Puk Clutch/2400lbs Pressure Plate
- Machined Fly-Wheel
- GT3582 Turbo
- DW 950cc Injectors
- Drift Side Racing Front Mount & Piping
- Braided Turbo Oil & Water Lines
- Top-Mount Manifold (Heat Wrapped)
- 3" Down-pipe (Heat Wrapped)
- Brand New Turbosmart 40mm Wastegate Plumbed Back
- Greedy Blow Off Valve
- K&N 9" Intake Filter
- Walbro 500HP Fuel Pump
- D2 Adjustables In Front
- Cusco Adjustables In Rear
- Battery Relocated To Boot
- A/C Removed
- 18x8 TSW's
