New here
12 September 2016
Auckland
Hi everyone in new here just got a s15 today I'm from New Zealand
would like to get help and advise cheers
will post photo of car also 🙃
Joeh
12 December 2006
www.silivaoc.com
@silviaownersclub
Upload a picture from inside the boot, usually that is the biggest give away. (take a picture close to the rear panel where the lights are)
The inlet manifold and cam cover design is not from S15 Spec R but it might have just had a replacement engine or someone was experimenting.
Not the original motor. The black top SR20's in the S15 didn't have a distributor. I would guess the motor is an S13 red top
That was originally an NA...look at the inlet runners and distributor. It's had the turbo added...what boost is it running ?
Joeh
12 December 2006
www.silivaoc.com
@silviaownersclub
I was thinking that however one key factor is that the inlet manifold that it's running is something that was only on older S bodies, so I was considering the possibility that it could be a forged engine from another model that's just been transplanted in with the large turbo.
12 September 2016
Auckland
Found out a little more info this morning
Body is a Spec-S with 103,000K's with a SR20DET swap with motor around 32,000K's
Everything is Certed & Have Just Put on WOF & REG
- SR20DET (32,000K's)
- Link G4
- 5-Speed Manual Transmission
- 6 Puk Clutch/2400lbs Pressure Plate
- Machined Fly-Wheel
- GT3582 Turbo
- DW 950cc Injectors
- Drift Side Racing Front Mount & Piping
- Braided Turbo Oil & Water Lines
- Top-Mount Manifold (Heat Wrapped)
- 3" Down-pipe (Heat Wrapped)
- Brand New Turbosmart 40mm Wastegate Plumbed Back
- Greedy Blow Off Valve
- K&N 9" Intake Filter
- Walbro 500HP Fuel Pump
- D2 Adjustables In Front
- Cusco Adjustables In Rear
- Battery Relocated To Boot
- A/C Removed
- 18x8 TSW's
