Hi guy's/girl's
Oki this is my first spec's thread since I've joined a while back ago.
02 Nissan Silvia Spec R Aero
Engine mods
HKS - Super SQV BOV. with recirc. kit
HKS - Fuel Pressure Regulator (set to standard 3 bar)
HKS - GT-RS Turbo Kit (ported to prevent boost creep)
HKS - Adjustable Actuator
HKS - EVC VI boost Controller
HKS - Intake Hard Pipe
Denso - Iriduim SparkPlugs
Sard - 850CC injectors (injector cap screw M5x0.8x16)
Nismo - Fuel Pump 4.1Litre/min
Nissan - Z32 AFM
Tomei - RAS Kit
Tomei - Expreme Exahust Manifold
Tomei - N2 Oil Block
GReddy - Large Alu Baffled Oil Sump
GReddy - Pulley kit
Blitz - Nur Spec R cat back exhaust
Moonface - MF-R Chamber Pro (elbow/front pipe)
Samco - Radiator Pipes 'blue'
Apexi - Power Airfilter
Apexi - PowerFC with hand commander
Cusco - Oil catch Can x2
Spitfire - Di Ignition Coil pack
Spitfire - Di Bridge
Spitfire - Ground Wire Kit
Nissan - Z32 Fuel Filter
Fuch/Silkolene Pro S - 5w-40
Power Enterprise - Super Kevlar Belts Set
Power Flex - Poly-Urethane Exhaust Hanger
Tomei - Type A Valve Springs
Tomei - poncam Type R (256deg 11.5mm lift Ex/In)
Supertech - Valve stem seals
Brain Crower - Ti Spring Retainers (BC2200)
Cosworth - MLS head gasket 1.1mm
ARP 204-4204 Engine Head Studs Bolts Kit
Transmission mods
Orgura - ORC409DS (single plate Clutch)
Nismo - Braided Clutch Line
Nismo - Strengthened Pivot
Uras - Imo Youkan Transmission Mount
Motul - 90PA Diff Oil
Moonface - Magnetic Drain Plugs (oil,tran and diff)
ATS - Metal Diff 2way
Nissan - 4.08:1 final drive
Cooling Mods
Blitz - LM Intercooler
Koyo - 53mm Alu Racing Rad
Garage Defend - GT Cooling Panels
Weld - Alu ABS Heat Shield
GReddy - 16 row oil cooler with oil filter relocation and thermostat
Interior Mods
Moonface - MF-R Gear Knob
Razo - Aluminum Foot Pedals
Cusco - Brass Shift Collar
C's - Short Shift (6mt)
Defi - Controller Unit 2
Defi - 60mm BF Boost Gauge
Defi - 60mm BF Oil Pressure
Defi - 60mm BF Oil Temp
Defi - 60mm BF Fuel Pressure
Bride - Gais Bucket Seat (Carbon Kavlar)
Bride - seat rails driver only..
Nardi - 330mm Deep Corn Steering wheel (pref. leather red stich)
Works Bell - Short Hub Boss Kit
Works Bell - RapfixII Quick Release
Nismo - Cluster Gauge
Handling mods
Cusco - Type ALC OS (front Struct Brace)
Tein - MonoFlex Coilover 7kg/5kg
Rays Engineering - Volk Racing TE37 18"x9.5" +12
Toyo - Proxes T1R Front 245 40 r18 Rear 265 35 r18
Kics - R40 Neo Chrome Wheel Nuts
Front Suspension
Ikeya Formula - Tie Rod with spacers
Megan - Adjustable Tie Rods Ends
Apex Performance - adjustable caster arm (rose joint)
Whiteline - Anti-Roll Bars front (adjustable)
Nismo - Steering Rack Bushings
Hardrace - roll centre adjuster front
Apexperformance - Front Lower Brace adjustable
Rear Suspension
Tein - Rear strut bar
Parts shop Max - Traction Rod
Hardrace - roll centre adjuster rear
Apex Performance - rear subframe C Collars
Apex Performance - adjustable camber arm (rose joint)
Whiteline - Anti-Roll Bars rear (adjustable)
Nissan - standard toe arm with power flex adjustable poly bushing
Nissan - Z32 alloy rear knuckle conversion
SPL - Z32 sphrical rose joint for suspension lower mount
Super Pro - poly bushing for Z32 rear knuckle
Whiteline - Rear Knuckle Poly Bushings
Brake Mods
Motul - RBF600 dot 4 brake fluid (312degree C boiling point).
Nissan - Z32 BMC (BM57)
Front
Brembo - R34 GTR front Calipers (44mm and 38mm pot calipers x2)
Project Mu - SCR Slit 324mm Dia. x 30mm Vented Discs
Goodridge - braided hose (conversion hose for r34 caliper)
Nissan - standard brake pads
Rear
Brembo R34 GTR Rear Calipers (38mm pot calipers x2)
Brembo - 296mm Dia. x22mm Vented Discs (z32 discs) GTR size is 300mm
Note***-Z32 disc has a smaller pad contact surface then R34 discs-Dia. x 22mm
Ferrodo - DS2500
Goodridge - braided hoses (conversion for r34 calipers)
Nissan R33 rear drum brake assembly conversion
-backing plate
-hand brake assembly
-hand brake cable
Exterior mods
T&E Carmake - Vertex Ridge Widebody System
8000K HID kit with relay kit
Bellof - Sirrus Led Sidelights
Nismo - Smoked wing lights
Moonface - MF-R 30mm blanking cap (rear wiper remove mod)
ICE
Pioneer - AVH-P5900DVD player
Pioneer - BTI200 Handsfree Bluetooth Adaptor
Pioneer - I200 Ipod Adaptor
JL Audio - 300/4 Slash Series 4ch Amp
Focal - 6.5" Polyglass v2 165VR Component Speakers (Front)
Focal - 6.5" Polyglass 165CVX Coaxial Speakers (Rear)
Fusion - Amp Wiring Kit
Performance
results of the roller.
@WCP Tralee (12.05.2012)
boost was still dropping off from 1.6 to 1.2
398hp @ Fly - 400 ft/lb @ Fly
@CDA (23.01.2012)
(with cams and head work done and plenum and bigger TB boosting 1.5bar on E5 fuel)
boost was dropping off
378hp @ Fly - 320hp @ Wheel - 360 ft/lb @ Fly
Recent ish pics
Engine mods
Nissan - Z32 AFM
Tomei - RAS Kit
GReddy - Pulley kit
Transmission mods
Cooling Mods
Interior Mods
Handling mods
Front Suspension
Rear Suspension
Brake Mods
Front
Rear
Ferrodo - DS2500
-backing plate
-hand brake cable
Exterior mods
ICE
Performance
@CDA (23.01.2012)
Recent ish pics
