silvialam
Hei guys, this is Lam from malaysia,just want to share some mods that i had done on my silvia S15 JDM specR , do give some comment and also share some info to me on how to make it even much better ride!
Engine Spec:
Apexi PowerFC D-jetro
MSD DIS4 high power ignition Amp
Garrett GT series turbine
HKS actuator kit
Tomei Poncams Type R IN/EX 256degree 11.5mm lift
Tomei rocker arm stopper
Tomei valve spring
Tomei adjustable cam gears(exh side only)
Tomei 740cc injectors
Tomei 248 ltr/h fuel pump
Tomei upgraded oilpan
Tomei ornament plate
Greddy pulley kit
Greddy Type RS blow off valve
Greddy TYPE S boost controller
Greddy oil catch tank
Greddy oil cap
K&N 80mm air filter
HPI engine damper
URAS cam angle cover
Exhaust system:
Tomei EXPREME manifold + Tomei exhaust thermo wrap
Tomei EXPREME downpipe
RS.R front pipe
HKS Power Titanium tip muffler
Drivetrain:
Stock s15 6speed gearbox
HKS twin plate
Nismo slave clutch pump
Nismo release pivot
GT Auto Custom steel braided clutch line
Cooling:
Blitz LM intercooler
Greddy aluminium radiator
Blitz silicon radiator hose
Sard racing thermostat 68 Degree cc
Garage Defend GT cooling panel
TRUST oil cooler kit
Brakes:
Brembo GTR34 front(4pot) and rear(2pot) conversion
Brembo GTR34 brake disc front & rear(original)
Endless 800cc brake pads(front)
Endless 800cc brake pads(rear)
Cusco brake stopper kit
Wheels:
17" P1 buddy club F 8.5j R 9j
Rays Engineering wheel nuts and lock nuts
Handling:
Yashio Factory coilover
Yashio Factory pillowball
Ikeya Formula rear camber adjustable upper arm
Ikeya Formula rear Tracton adjuster rod
Ikeya Formula front tension rod
Nismo power brace
Cusco antiroll bar
Greddy front strut bar
Exterior:
Yashio Factory full bodykit
Ganador Carbon fibre Aero side mirror
Boss Auto Produce carbon hood
Origin labo CF side canard
Cusco bonnet pin
Nismo smoked side lens
Nismo fuel filler cap
Interior:
Greddy remote switch (boost)
Defi BF amber red meters
(Boost,Water temp,oil temp,oil press,fuel press,exh temp)
Recaro SR3 seats with original s15 recaro rails
Nismo meter cluster 280km/h
Nismo GT Titanium shift knob
Nismo racing switch cigg lighter
Greddy Turbo Timer
Lubricant:
Top Secret Fusion 15w/50 engine oil
KAAZ front gearoil
HKS rear LSD gearoil
Motul radiator coolant
Motul Dot5.1 brake oil
**pictures are not latest one, so there is no CF canard and Tomei ornament plate. Will post the latest picture soon... stay tuned
Engine Spec:
HKS actuator kit
Tomei valve spring
Greddy pulley kit
Greddy oil cap
K&N 80mm air filter
HPI engine damper
Exhaust system:
RS.R front pipe
Drivetrain:
HKS twin plate
Nismo release pivot
Cooling:
Brakes:
Wheels:
Handling:
Nismo power brace
Cusco antiroll bar
Exterior:
Cusco bonnet pin
Interior:
Greddy Turbo Timer
Lubricant:
KAAZ front gearoil
