Hello from Germany
11 December 2008
Germany
Hi there!
In November a dream came true!
I bought a S15 Spec-R from Sabeimports.com.
It´s a 2001 with HICAS, Nismo Swaybars, Nismo/Impul Exhaust und Impul Wheels.
There´s still some work to do before the car will see the Nürburgring in March or April 2009.
Here´s a pic, now lowered with a K-Sport Suspension.
greetz,
Benne
mint
18 March 2007
Asakusa, Tokyo
www.JDMtas.com
How to do that?
Would it be enough to remove the HICAS Fuse?
Or do i have to block the Hicas mechanical?
yes you can remove the fuse however your obviously still going to have all the HICAS mechanism, The easiest way is by getting a HICAS Stopper Kit - Kazama does one for the s14 iirc (s15 too maybe: at work cant check >.<' )- It should be the same.
The kazama stopper kit does it job, I believe that it replaces the rear steering rack, but you are still left with the tie rods.
you could get a rear subframe from another non-hicas s15 however you would still need to change out the powersteering pump and resivor.
However, Im no expert so someone might pop along soon with more info?
