Arch Rubbing Issue
40200-5L310 is shown as being the same for 09/98-> S14s and all S15s. Although 40200-0V010 will probably fit, it isn't an exact replacement.
Darren_S15
Club Event Orgainser
18 January 2008
Essex, UK
Do you think I should fit it then?
Im leaning towards sending it back and getting the 5L310 just incase the otherone is not correct for some reason.
Darren_S15
18 January 2008
Essex, UK
Quick update on this.
Ive spoken to the shop I got this part from and they have told me that both the 0V010 and 5L310 are exaclty the same part and all the number wirtten over both hubs are the same.
So Im going to go ahead and fit the 0V010 and let you guys know how it goes.
As I said, it'll probably fit. I believe people have fitted S14 bearings on S15s before without issue. Chances are that a minor change was made and the number was changed. Certainly the newer number isn't an alternative number for the older (done if a new part REPLACES an old one). :)
5 October 2009
Hi Darren,
Old thread dig out, did you solve this with the bearing?
Your symptoms seem to be exact of what I have.
I had the wheels off 3 times and had brakes apart twice :(
Look forward to your respose,
Cheers,
Darren_S15
18 January 2008
Essex, UK
Replacing my hub made no difference.
Eventually worked out it was the caliper that was broken, hence the brembo upgrade which did solve the issue.
The rubber piston seals had gone from the caliper and the piston was totally stuck in.
5 October 2009
Ok good to know,
I'm running r33 brembos on front already. Will pop out the pistons and give it a good clean next week.
I did notice that the dust seal was out on one of the four pots when I took out the pads so this could be the culprit.
Will let you know how I get on
Thanks for your reply
Darren_S15
18 January 2008
Essex, UK
I still have the old hub + bearing I took off the front - I kept it becasue I don't think there was ever anything wrong with it in the end.
Might be worth a try if you did think it was your hub, paid about 150 for my new hub.
5 October 2009
will keep that in mind, Will try the caliper first if it still does it will let you know
thanks
