how many HP?
18 June 2008
Russia
engine specs:
intercooler HKS type-S
Walbro fuel pump 255L/h
greddy 7 spark plug
Exhaust HKS Hi-POWER Silent 76mm
GREDDY hot pipe
AUTOBAHN88 outlet
NISMO frontpipe
test pipe
boost - 0.85bar
i don't have dyno in my city(Russia=()
please tell me how many HP i have now(approximately) and what i need to buy for 320bhp
ECU, injectors, z32 MAF sensor(or not?)what else?
Toby
Rocking on for 300 I'd say, No real need for the MAF untill you change the turbo out TBH!
28 July 2009
I reckon about 270-280. You really need a full 3" exhaust and map to push just over 300 on that setup
18 June 2008
Russia
i have now 3"(76mm) exhaust....
19 January 2010
fctuning.com
Well first of all.... if its numbers your after....at your current level of boost most your engine will most certainly be no where near a calculated 300hp at the flywheel (unless you have super fresh compression or higher for that matter, or unless your ECU has been properly seen to and setup )
sample
at 0.85 bar you'll be looking at around 210-215@ the wheels Estimate 260-265 at the fly on a good day
with your ignition timing an fuelling fine tuned at a lowly 0.9bar with similar mods, you'll be looking at something along the lines of this
http://fctuning.com/fctwp/?p=226
Hope that help serve as a nice reference for you, and the club members :)
Steve@FCTUNING
ps
17psi (1.25bar) and your looking around this
http://fctuning.com/fctwp/?p=677
It's the increase in torque that's most fun, esp 343 ftlbs of it ;)
ms110
to hit 320, mainly you need to change turbo, z32AFM and ECU, at the moment should be 240-250.(i guess)
28 February 2010
Brisbane, Australia
my car has practically the same mods as yours and pulled approx 222hp atw... but that was running 7psi boost
19 January 2010
fctuning.com
thumbs up :)
the factory S15 turbo can be comfortably tuned to 320hp with ease, providing its equipped with a decent actuator on it (or even factory actuator with plenty of oooomph in it). and by that. I mean one that doesnt drop off too much towards the red line.. its fairly normal if boosting to 1.2/1,3bar for boost to drop back to 1.1bar so dont be surprised... Trust me fellas I see this day in day out and have proved it time n time again in front of 100s of Nissan owners Around the UK and Europe
Jez...n all the S15 turbo is technically speaking a T25 (as it used a T25 turbine inlet)... the technical name (part number providing) given to the S15 turbocharger unit is a GT2560R (lets not forget what Mr Garret calls it,hehe ;) ) Its a ball bearing T25 in effect (which is why the little bugger spools so damn well and makes heaps of torque nice n early in the rev range.. a Fantastic Street Turbo. they should have fitted these things to all the bloody nissans in the first place...
http://www.turbobygarrett.com/turbobygarrett/catelog/Turbochargers/GT25/GT2560R_466541_4.htm
tooley
When only sideways will do!
10 October 2009
West Midlands / South Wales
see i dont think my 2002 has the BB turbo... not that it matters as this thing flys :D However i am saving for a map from steve!
18 June 2008
Russia
thumbs up :)
google says that all s15 has t28 garret
finally...what i need for 320bhp:
new actuator.
boost controller
ECU(stock ecu is good for tuning?)
What RON is your fuel in Russia?
