Japspeed
- 27 March 2009
- Manchester
- www.japspeed.co.uk
HI Guys
We have a great offer for you guys on Exedy Clutches through the month of July!!
EXEDY was founded over 50 years ago by Kazuma AdachiMore who strived to provide a better clutch for the Japanese Auto Industry, he has most certainly succeeded and EXEDY is now probably the most known clutch brand in the world!!!
Its is this reliability and performance in EXEDY clutches which has brought us to becoming a stockist of there products and we have many of these on the shelf and ready for dispatch for next working day delivery. :thumbs: If we've not got the clutch you require in stock we can get this within 48 hours and shipped to you!
As always we are going to provide you with an irresistible offer so see below for details!
We have available for immediate dispatch EXEDY Nissan S13 180sx 200sx S14 and S14A & S15 Stage 1 Organic Clutch Kit
The EXEDY Sports Series Stage 1 Organic clutch Provides a 20% increase over the standard torque figure and is ideal for motorsport use incorporating friction material with high heat resistance properties and high strength fibres making the Sports Series an ideal clutch for street, circuit or drifting.
Features:
High Heat Resistance
The performance of a standard organic friction material usually suffers after slipping, accordingly EXEDY have developed the "Ultra Fibre" asbestos free material which retains high friction co-efficiency after being subjected to conditions associated with motorsport applications and unlike competitors materials, if "fade" is experienced the EXEDY "ultra fibre" material will recover after a cooling down period.
Tumbler Strength Increase
Modifications to the friction material composite, specifically the copper weave will increase the heat-resistance characteristics and burst strength material with steel plates which is a common practice in some parts of the world.
Abrasion Resistance Up
Overuse of the clutch system in the partly released position or use in a motorsport environment will adversely impact on the wear rate of a conventional organic friction material unlike EXEDY's "Ultra Fibre" friction material which has a stable wear rate over a wide temperature range.
We also have available EXEDY Nissan S13 180sx 200sx S14 and S14A & S15 Stage 2 S-Type Clutch Kit
The EXEDY Sports Series Stage 2 Paddle clutch Provides a 40% increase over the standard torque figure and again like the stage 1 is ideal for motorsport use incorporating friction material with high heat resistance properties and high strength fibers making the Sports Series an ideal clutch for street, circuit or drifting.
Features:
S-Type Metal Disc
Unique metallic configuration and low gravity metallic material, T5001 Carborich, made lightweight (Inertia is 10% lower than the genuine part). This thick type disc has excellent heat dissipation characteristics. The series can be applied to street as well as the competition user. They are also applicable to rally for which torque and high heat resistance are required, and to street sports for longer life.
Clutch Cover
The Exedy S-Type Clutch Kit is supplied with a reinforced clutch cover designed to achieve a clamping load that is 40% higher than the genuine part enabling a higher torque transmitting capacity. Ductile material is used for all p.plate and high burst strength can be achieved un all temperature ranges.
We are offering these during the month of July with 20% discount subject to the item being in stock - giving you guys the following prices!
S15 ONLY
EXEDY Nissan S15 Stage 1 Organic Clutch Kit SR20DET - £226.42
or
EXEDY Sports Series S15 Stage 2 Paddle S-Type Clutch Kit SR20DET- £276.68
The above prices include shipping to UK mainland! :nod:
If you require this to be shipped overseas then please contact for a shipping quote.
We Run EXEDY Hyper series Twin Plate clutches on our Japspeed Driftcars (Pictured Below) and the Hyper serious Multi Plate clutch can handle 700Nm of Torque
If you require a Hyper Series clutch we can include this as part of this offer meaning you can get these at a great price too!
Please contact for Price and availability.
So when your looking for a clutch Get in touch!!!!
You can call today on 08444 489 080 to purchase at the individual price!
I look forward to sending lots of these out to you!
Regards
Paul
Features:
Features:
S-Type Metal Disc
Clutch Cover
S15 ONLY
or
Regards
Paul
