T
TrIcK^
Ill share this here as it may be a good reference.
Took the 15 to get an alignment check today as it nearly killed itself and me a few days back
Anyway, the display below shows what happens when you just 'deck' it on coilovers without a care for anything else.
The after display is after it has had a tickle. The car has no adjustable arms, so it simply is as best he could get it. Had to settle on high rear camber as one wheel could not be dropped below and 2 degrees on front to avoid scrubbage, but overall Im happy considering. The best bit? All in for £45
