apex intercooler
28 August 2010
belgium
hey guys
I am buying pieces for swapping int sr20det
but I need some info of some pieces!
above the battery is a part that I do not know.
does anybody know what this is because it was not connected with the purchase??
even at the apex intercooler are some pipes that I can not identify
I put it in yellow
2 large terminals?
1 smal voor idle,and 1 voor boostregulator i guess.
also with the intercooler is and extra boost nipple, is for the boost gauge?
hope you guys kan help me :nod::eek:
also have buy and hks ssqv bov! where is the best place to install this intake of turbo side ?
Top picture is the sensor for the factory boost gauge I believe,
As for pipe connection,one will be for the recirc/dump valve.not too sure bout the rest. .sure someone will clear it up for ya
factory boost solenoid (black box on inner wing) - block off/disconnect if not using standard boost gauge
the two large connections on the pipework are for the re-circ/dump valve
the small nipple on the intake is for factory boost solenoid - block off
the thinner pipe on the largest pipe is to connect to the hose that comes from under the intake manifold
not sure whats in the bag, may be a quick tap boost nipple.....
28 August 2010
belgium
hey,
thanks for the quick response :thumbs:
the two large connections on the pipe work are for the valve re-circ/dump
so I can weld it shut :nod:
in the bag, is a quick tap boost nipple, is this for new boost gauge?
and where is the best place to install the bov. intake of turbo side
thanks,
greetings
the bov fits on the large connection on the largest pipe, the intake pipe from the filter has a large outlet that gets blocked off if you are running atmospheric. the quick tap nipple fits in the silicone hose that comes off the turbo on the high pressure side, this is for the boost control method before going to actuator :)
