apexi fc controller!
14 May 2011
northamptonshire
hi,
i havnt got a clue how to use it and for some reason my car is running at 0.5bar boost, anyway to turn it up or try to sort using this?
thanks
martinbattye
unless you have a powerfc boost control kit then it wont turn the boost up.
26 May 2009
Frozen Canada eh!
I wouldn't recommend messing around with something that acts as the brains for your engine...
Fit a separate boost controller,makes it easier then the Power FC boost kit
martinbattye
the FC commander is a great tool..
if your a total newb then just go into the monitor menu and set how ever many channels you like to view their parameters..
has it been mapped?? if so your tuner would usually go thro how to work it with you.. if not they are bloody lazy.
you can also check if your tune is locked so your cant damage anything..
go into the settings menu..
go into fuel map.. if all the numbers are zeros or another odd number then its been locked. which means you cant cause any damage..
