R
Russ
hi all, im abit miffed as to where the bov would go, iv seen multiple videos with it placed in various locations, so where is best?
thanks
thanks
when cold, very important otherwise you will burn your wittle fingers, undo the locking nut or nuts if there are two of them on the arm, the turn the female sleeve so that the arm gets tighter then lock it up again, you will have to remove the tiny circlip holding the arm to the turbo exhaust housing slide it off (dont loose the circlip) wind it tighter, just a couple of turns at a time, then put it back on and BOOM, more response.yea im still trying to work out how to do it, haven't tried too hard yet. Spoonman can you check out my release bearing thread i commented on
I was definately under the impression, and from numerous reliable sources, that the blow off valve was there to protect the turbo.hey,
the bov should be as close to the trottle body as possible! target is to protect the throttle body,when you go under full trottle of the trottle a huge pressure is bild up and so could damage the valve(and so parts of iron can come loose, and damage the engine)! if fit the BOV here the intercooler remains under pressure but this is also a benefit when you get back on the trottle!:nod: faster response :nod: if the turbo stil stalls, is in my opinion poorly adjusted.
if not correct they fooled me at schooland our teacher Sat almost on f1 level engeneering:nod:
I have been under the same impression also. A throttle body is a lot more sturdy than the internal components of a turbo so in my opinion it's the turbo that needs looking afterI was definately under the impression, and from numerous reliable sources, that the blow off valve was there to protect the turbo.
