- 24 July 2010
- QLD - Australia
- www.omgpham.com
Hey guys.
Well my S15's VTC gear rattle is getting very bad now, so I've decided to pick up some adjustable cam gears and chuck them in. But before I attempt to do the installation myself, I thought I'd post some questions for the experts here. I've had a read through the TIMING CHAIN section of the FSM, but a few things are still unclear.
From my research it looks like I'll need to source a S13 intake camshaft bolt, because the S15's intake camshaft bolt is too long due to the VTC gear. I guess I'll call up some Nissan wreckers tomorrow to try source one, or would it be best to buy brand new genuine?
On the EX side... when I remove the cam gear, will the 'worm gear' looking thing separate from the gear sprocket? Because the cam gears I have don't have that 'worm gear' looking thing on it.
Getting everything to TDC should be pretty easy according to the FSM, just align the markings to the silver coloured links in the chain.
In regards to gaskets/seals/o-rings, should I get new ones?
Rocker cover gasket, spark plug gasket?
Will I need a tune if I don't adjust the cam gears? Just keep it at stock timing is what I mean. And stocking settings would mean ZERO degrees advance/retard?
While the cover is off, will be installing RAS too.
Thanks for the help guys and if there are any tips, please feel free to post![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
