car is vibrating...
silviac
it happened about 3 or 4 times recently.
When I turn my car on, i feel some very unpleasant shakeness through my gearbox and whole car. like a tractor
Could it be coilpack or one of spark plug out?
If I turn the car off and turn it back on after few seconds it is ok.
Do coilpack or spark plug go off instantly or die slowly like on off on off...
any idea?
Y
yewei
hmmm did ur car sounded like a subby when u turned it on? :confused:
:nod: Could be running 3 cylinders. Check the sparks first, then the coilpacks. Dying coilpacks do so intermittently to start with.
silviac
alright so once i check them how do i know they are out?
i got NGK spark plug anyway so might as well replace them :)
Y
yewei
hmm how long have u been using the current plugs? are they aftermarket ones? nissan's original plugs are from NGK! :thumbs: :cool:
If you've not change them recently, do so.
To trace a coilpack problem, you could do with borrowing a spare. Check that all the connectors are secure first :nod: Leave the spark cover off. Next time the car does its rough running, leave it running and tweak each connector to see if the problem goes.
