Caster and Camber Adjustment
henrico
14 June 2009
Surrey
Hi,
I've just had another 4 wheel alignment done on my car and the caster and camber are out but non adjustable. What's the best option for getting these adjustable?
Btw if anyone needs this doing and lives surrey/hampshire way then go to Micheldever tyres. They are awesome and really cheap ;)
Cheers
Front camber can be adjusted if you fit aftermarket coilover suspension which include adjustable top mounts...
Rear camber can be adjusted if you replace stock arm with an adjustable camber arm.
Front caster can be adjusted if you replace stock tension rod with an adjustable version.
Rear caster cannot be adjusted AFAIK but then again don't think you really need to!!
Driftworks do all the geometry suspension parts like camber arms, tension rods etc:
www.driftworks.com
Cheaper but IMO no less inferior than the Jap stuff. But a lot of people go for JDM manufacturers like Ikeya Formula mentioned above or Tein, Cusco etc...
www.rhdjapan.com
henrico
14 June 2009
Surrey
Sorry to bump the thread but has anyone got any links to any websites for the part I'm looking for?
