dials not lighting up
sniffy
27 February 2007
Co.Wicklow Ireland
has anyone had the problem where you dials(speed revs) wont light up mind just went last nite for not reason drove the car parked up for an hour came back to the car and they wouldnt light up . im thinking fuse as the heater controls wont light up either as welll as the back licence plate light.
Yeah, could be the 'METER' fuse. There's a translated fuse diagram in Useful Threads :)
sniffy
27 February 2007
Co.Wicklow Ireland
got it sorted thanks was a fuse in the box in the engine it was the tail lights fuse.
31 August 2007
Ashton, Manchester
On both the S15 I have had the fuel gauge is very dim nowhere nearly as bright as the ones around it,is this common?
Your cluster bulb needs replacing on that side. Chances are it'll be blacked up. I replaced a load in my pod. Cost a fortune for Nissan bulbs :rolleyes: There's a guide on my Tech site for replacing them, along with a diagram of which bulbs go where and the three PNs (there's three different wattages).
Don't be tempted to use LEDs. The colouring of the backlighting and warning lights depends on the hue of halogen bulbs. You get pink warnings and blue indicators, etc if you use LEDs.
sniffy
27 February 2007
Co.Wicklow Ireland
on the climate controls some of the bottons dont light up is it easy change the blubs in it ?
