Drag S15 build in the US.
Just found this on freshalloy.
http://forums2.freshalloy.com/showthread.php?t=178421
Zero4SPL said:
Here's some specs on the car:
Mazworx/PRL Racing Pro Modified Drag S15
NDRA Pro Modified
SR22VET
Engine
Mazworx Build SR22VET
90.0mm 11:1 CR CP Pistons
86.0mm OEM Nissan Crankshaft
Mazworx Custom ALuminum Connecting Rods
Calico Coated ACL Race Bearings
Darton Sleeves
Aviaid Dry Sump Pump
Mazworx Dry Sump Oil Pan
ATI Dampner
Mazworx/Power Enterpise 90mm Headgasket
Mazworx 1/2" Headstuds
Mazworx CNC Ported Cylinder Head
Mazworx CNC Combustion Chambers
Supertech Valetrain w/ Inconel Exhaust Valves
Nissan SR16VE N1 Cams
Mazworx Custom Shimless VE Head
Tomei Cam Gears
Power
Fuel-Methonal
Mazworx Custom Intake Manifold
OEM Nissan Q45 Throttle Body
Mazworx Silicone Couplers
Garrett GT4508R 1.44A/R
Mazworx Divided Exhaust Manifold
Tial 60 Wastegate
5" Stainless Downpipe
6" Turbo Intake
Mechanical Fuel Pump
12 x 160lb Fuel Injectors
Electronics
Motec M880 ECU
Motec CDI 8 Ignition
Motec ADL Dash Logger
Custom Engine/Body Harness
Motec Complete Data Aquistion
Denso Coils
MSD/KONI Shock Controller
16 Volt System
Drivetrain
RAM Dual 7" Slipper Clutch
Browell Aluminum Bellhousing
G-Force 2000 Transmission
Custom 4" Aluminum Driveshaft
Strange Pro 3rd Member
Strange Spool w/ 40 Spline Gun Drilled Axles
American Racing 15 x 15 Double Bead Lock Rear Wheels
AMerican Racing 15 x 3-1/2 Spindle Mount Front Wheels
Goodyear 32.0 x 14.5 x 15 Rear Tires
Goodyear 23.0 x 5.0 x 15 Front Tires
Chassis
Mazworx Custom 25.1E Chrome-Moly Chassis, RHD
Strange Ultra Struts
Koni Electronic Adjustable Rear Shocks
Mazworx Custom Rear Housing
Quartermax Pro 4-Link
Quartermax Pro Wheelie Bars
Body
2000 Nissan Silvia S15 Body
Custom Fiberglass One-Piece Front End, Doors, Trunk
Lexan Windows
Mazworx Rear Spoiler
Interior
Carbon Fiber Tubs
Carbon Fiber Defuser
Carbon Fiber Panels
Custom Fiberglass Dash
Safety
Strange Front/Rear Brakes
Safecraft Halon System
Stroud Harnesss
Stroud Window Net
Sparco Steering Wheel
Sparco Steering Wheel Disconnect
Stroud Pro Stock Air Assisted Parachutes
Quartermax Remote Disconnect
Driver
Jason Greenawalt
Crew Chief
Mark Mazurowski
Owner
Patrick Linn
__________________
Mark
mark@mazworx.com
NHRA Sport RWD S14
9.07 @ 155 Best
gunner93
Thats a rare motor what more with a stroker. Great find!
Looks pretty nuts, will be good to see it in action.
C
christopher
What the?! SR22VET?
That's the Nissan X-Trail GT engine! SR20DET with variable valve timing and lift control... Where did they get that?
And stroker kit! Hm, that's serious
And where did I read about this article. They built an ultimate SR20DET with the S14 engine, because they said that SR20 used in S14 have more better piston angle, thus equipped with Tomei pistons for better power
screamracing
this sr20vet is made with a rwd sr20det bottom end and then adding a sr20ve head on to with alot of custom work done. the x-trail sr20vet is east west facing and so wont bolt into a silvia no sr20ve or t came in a rwd setup i heard a rumour they are going to put it in the new s16
