Derek
![](/discuss/proxy.php?image=http%3A%2F%2Fwww.daisyartworld.com%2Fimages%2Ftemp%2Fmotors%2Fkit%2Fkits_s14_silver_frontview1.jpg&hash=105cfdf378904f65ed5fe2fafd365c8c)
Length 31" (600mm)
Height 12" (280mm)
Thickness 3" (75mm)
Inlet 3"
Outlet 3"
Compress Air Flow Rate <700Cubic Feet/Min, Rated to 600-700 Max HP
Working Pressure: 35~40PSI
Pressure Drop 2~5psi@35psi; 0.2~0.5psi@15psi
Hot Air Temperature 32?F~302?F (0?C~150?C)
Material 100% Aluminum
Design Bar and Plate
Construction Machine Cut and Stamped, Hand Welded
Finish Polished
Net Weight 22 lbs
Contents of the Kit One 31"x12"x3" Intercooler
8 pieces of 3" Clamp
4 Pieces of Silicon Hose
Four Aluminum Pipes
Bolts and Brackets, Red hose
i wonder if its any good? Opinions?
I prices it just to see. I can get it delivered for around ?450 which is good.
