FS: Full Nistune package for S15r (S14a,S13r/x)
immy21
9 November 2012
Edinburgh
EDIT: SOLD
In short I am selling
1. Nistune fitted to S15 Spec R JDM ECU (no case)
2. Nistune software licence
3. Good quality Austrailian made consult cable
4. MAP sensor
5. DLP analog input cable for Data logging aftermarket sensors
6. D Link USB hub if bought as a package
All that new would cost £595 not including ECU, fitting and delivery charges (breakdown and individual sale prices below)
If you buy that as a package I want £sold + £20 insured mainland delivery
Contact me for overseas delivery
Now for the long version
1. Nistune Type 4 board board fitted to JDM S15 Spec R manual ECU, No NATS to worry about.
Has feature pack 1 so can do launch control, boost control with gear/speed using MAC valve on OEM wiring, electric rad fan control, simpler tuning with TIM etc
Hdev new price for board is £270 + £30 fitting + delivery
My sale price is £200 + £15 delivery
Not supplied with ECU case however easy to fit into your own, just a bunch of screws that's it.
Addition screws to hold in the Nistune board are supplied.
These are 64pin, same as S14a, some late S14, S13 180sx Type R/Type S
Therefore whole ECU can be fitted into any of those cars by moving some pins 4 pins around.
Search it out, it's straight forward and fairly common with powerFC owners.
Alternatively have a computer shop or your tuner swap the Nistune board into your ECU
Your tuner will have to use a Nistune Base image programmer on the Nistune board to suit your ECU if it's not a S15r
Type 4 board works with the following vehicles but will need the base image reprogrammed if fitted into those ECU's
Nistune Type 4 ECUs
B14 NX2000 (SR20DE) [upto 1995 only]
K11 Micra (CG10DE/CG13DE) [later model]
N15 Pulsar (GA16DE)
G20 Infiniti P10 (SR20DE) [upto 1997 only]
P11 Primera (SR20DE) [upto 1997 only]
S13 180SX "Type R" / "Type X" (SR20DET)
S14A Silvia/200SX (SR20DET)
S15 Silvia/200SX (SR20DET)
S14 240SX (KA24DE)
ER34 Skyline (RB25DET)
WC34 Stagea (RB25DET) [Late Model & JECS ECU]
U13 Altima (KA24DE) [upto 1995 only]
Y33 Cedric (VQ30DET)
2. Single user Nistune mapping software/licence, allows you to tune up to 5 different ECU's
Hdev new price £200
My sale price £140, it's not exactly a wear and tear item :wack:
The licence is transferable, so I will tell Mr Nistune you are the new owner and you will receive a new product key under your details, then download and install. Even if your not tuning, super handy to have. Have a problem? Datalog and send it to your tuner. Need put a drivable basemap on? Have your tuner send you one and withing a few clicks it's on your ECU. What to put a valet rev limit? test your electric fan?
etc
3. Blazt consult cable
Hdev price £65
My sale price £40 + £5 delivery
A good quality cable is essential, I have no connection issues, can log a long journey no problem.
4. MAP sensor
New price £15
Not for sale separately
Same sensor used in expensive ECU's, I would say essential for road data logging/tuning
5. DLP 8 channel data logging USB cable
New price £25
Sale price £20 delivered
Feed any 0-5v analog out put of your favorite gauge or sensors for data logging directly into Nistune software.
Also has 5v power and sensor ground connections for connecting only a sensor directly to it.
I was logging: wideband, MAP sensor, KS4 Knock sensor.
Use your imagination, can log anything.
6. D-Link 7 USB hub
New £20
It's a powered hub but I used it not powered, no issues.
I had this permanently wired in the car with Consult, DLP data logging cable and wireless mouse receiver plugged in. This way just a single USB cable from hub to Laptop would do everything, worked flawlessly.
Edit for pics:
Edit for pics:
These 6 screw to remove/fit
And the ones one the sides, easy
DLP data logging cable and Consult cable
Dlink USB hub
24 January 2013
Kent
That's a whole lot of kit! Do you know if the software works on Mac laptops or it's only windows based?
immy21
9 November 2012
Edinburgh
I can't say for certain but I would have thought Mac users will be accommodated some how, I'l have a search of Nistune and try and find out for you.
Edit:
This seems a good reply, dual boot seems the best way but you can download and install the software without licence and see:
Nistune on Apple Macbook - Nistune Forums
Download the software here:
Install the top one
Software Downloads
