Gramlights 57Optimise
23 April 2007
UK
Gents
Im very close to putting a deposit down on these but need to confirm if the offsets will fit the S15. I dont want my wheels to stick out beyond the arch so bear that in mind.
Front 18x8.5 +33 Tyre 245/35/18
Rear 18x8.5 +33 Tyre 255/35/18
Getting a staggered set will cost me more money and more time as they need to be ordered however I think these will be fine. What do you think?
That offset will be fine for the size. The fronts will be tightish under the arches (depending on how much you lower) and coilover clearance close. I'd put 235x40x18 max on the front though. Handling with 245s will be terrible.
23 April 2007
UK
well theyre offering me a deal on a non staggered set but I would prefer a tapered wheel on the rear so will find out. They wont stick out will they?
23 April 2007
UK
sweet! Ill find out. What benefits are there of having a slightly wider wheel?
nope. Gonna borrow jonbubz's car because his car is running 18 x 9.5 +38 at the rear
Looks like there is quiet a bit of camber on the rear though.
Here are my wheels at the rear. 8.5J +30
camber is sorted now so they stick out a little more at the top.
Didn't have to roll the arches or anything though.
23 April 2007
UK
nice but i want to lower mine by 40mm so i think ill need to roll the arches.
Mine's lowered, an 18x8.5 on +32 offset and with the camber sorted. My rear arches needed rolling. I can't lower the front any more than in the photo without the arches hitting the rubber.
23 April 2007
UK
could you lower it if you put some negative camber on the front? or rolled the arches?
7 January 2007
Perth, Wait Awhile
The front is actually abit rolled from factory so I dont think you can roll them anymore. You need to roll the rears to fit anything decent.
I've read somewhere that wider rear wheels will promote more understeer? or was it oversteer. Cant remember
Added traction in the rear should increase understeer :nod:
With my BBS wheels which was 255 in the back and 215 in the front, I got mucho understear when I tried a tight cone course. I think you lot calls it "Motorkhana". It could be adjusted with the right foot though.
Haven't tried it with my current set of wheels though which are 225s all around. But I suspect it might be more balanced. I'm thinkng about trying this weekend.
B
baynz
i thout wider tyres on the rear would give you extra traction in a straight line but decrease your traction while turning a corner.
just what i thought tho.
23 April 2007
UK
just a quick photoshop. I want it as low as this. I think it will be achievable. what do you think?
(sorry pablo for using your pic)
23 April 2007
UK
by the way, i placed my order today for the wheels and i dont even have the car yet!! see how dedicated i am:cool:
