Greddy electronic gauge. Very stock looking.
Just found this on Greddy USAs website :)
This should be the closest gauge there is if going for the stock look.
No warning or peak hold though. But very close match to stock gauge.
Looks good :nod:
Do you need a control unit with those like you do with the Defi units?
Topper said:
Looks good :nod:
Don't think so. They have no other fuctions beside measuring from the sender.
I don't think Greddy has any gauge which require a controll-box.
The warning series comes with a separate box for every gauge.
warning and peak functions are controlled from the front of the gauge itself.
just_laze
Hey,
Did your wheels ever get fitted?
Would love to see them on.
laze.
13 November 2006
Swindon, UK
I've got the Greddy Data Link gauges. Exactly the same as above but with memory and warning light and they blend in perfectly with the stock look. I'll take some pics when i get the car back.
You mean the SM Integrate gauges?
Seems to be good units.
I've got the warning series ones.
13 November 2006
Swindon, UK
Not sure what series they are, but they react very quickly and it fits the turbo gauge pod perfectly :)
Just to warn you that if they fit the pod perfectly, they'll be too small for the vent, if you are planning using them. 60mm is good for the vents and will fit the pod if you shave the inside of the pod front (the thickness, not the visible edge).
E
evade
I have the 60mm greddy warning gauge with warning and peak functions..also it is a stand alone gauge..
comes with a map sensor you place in the engine, plug that into a vacuum source..
that leads to a little box..then one cable up to the gauge...no need for a seperate control box (defi style) or anything you buy it and it comes with everything you need.
cost about $250 AUD from nengun
its the grey one which lights up orange and matches (closely..its not as close as the pic suggests but it is pretty damn close..) the s15 dash.
i also have it fitted in a JDM a pillar.
13 November 2006
Swindon, UK
That's exactly how mine is mounted. Thought i was looking at my car then :)
Where did you take the light supply from? Cigarette lighter or somewhere else?
I connected everything to the stereo loom.
E
evade
yep mines connected mostly to the stereo loom as well
