grinding and steerin noises
26 February 2010
england
now and then when i put it in 1st or reverse theres a slight grind noise still pulls away fine bt with the noise now and then.and since last night after hitting weston with all the speed bumps the steerin makes some noises to.
any ideas??i have cusco coilovers on the old girl :)
Difficult to say... does it come from the gearbox area? Or maybe suspension related if the steering is making noises... what kinda noises??
26 February 2010
england
well when you turn the wheel left and right a fair way it makes a clunky sound if u get me??
mmm... when I used to get clunky noises on full lock, it turned out to be anti-roll bar drop links (front ones obviously)...
I'd get under the car and check these first. If not could possibly be CV joint maybe??
26 February 2010
england
well it started after going over some speed bumps in weston lol.
but aint on full lock sort of in random places :( steerin feels fine bt obvs the noise shudnt be there.i did wonder if it was cv joint thow hhmmm
B
barnes
Grinding could be Vvt rattle. Sounds the same as mine
26 February 2010
england
what when you pull away in 1st and reverse??
sx-si
7 June 2008
hampshire uk
proablly a tie rod end
or lower ball joint
or knackered tencion rod (if the bush is all the same colour its normally ok but if its wet its fubar)
i used to have a issue like that for like a year it turned out the stock bushs that clamp the steering rack in place had worn out
I could deffo tell when my tension rods went on the front... everytime I braked there was a loud clunk!!
And if you get someone to stand outside the car and look at it side on - drive to 20 mph and emergency brake... you'll see the car body move forwards and backwards when the wheel has already stopped?! Bad times!!!
26 February 2010
england
saying that when im parked up and rock it back and forward i noticed its bit boaty like lol.so tension rods it is then lol
26 February 2010
england
no hang on my mate explained something to me and sed its the bearings on the suspension cant for the life of me think of the right part name though haha(must b getting old or something ) ha
like they have dried up.top end bearing isit :S cnt think of it
Do you mean the top mounts?? If it's decent coilovers you got they should be pillowball top mounts which don't wear as quick...
26 February 2010
england
ye there cusco coilovers.
i see.so what would i have to replace??
If it's the pillow ball top mounts you can just replace those bits which go between the top of the coilovers and the suspension turret etc. I'm pretty sure you would be able to get these seperately as Tein retail their top mounts as seperate items.
26 February 2010
england
so shall i call a company who supply tein coilovers and ask if they can supply seperatly the pillow top ball mounts :) if you could point me in the right direction il be very greatful mate :)
No worries mate :)
I'm not sure if you can get Tein pillowball top mounts to fit Cusco coilovers... my assumption would be they are designed for specific makes of coilovers etc. Does no harm to ask the retailer though.
I got my Tein suspension and top mounts from Camskill (who are based up north I believe). If you Google search 'Camskill Performance' they should come up. Get in touch with them and see what they say mate.
26 February 2010
england
yeah i will thank you youve been great help :) thanks mate :)
