only said that (anneal the old) james as i remember something about someone getting the hoses with the wrong banjos/washers
Ah ok mate yeah I definitely think it's ok re-using the banjo bolts but my copper washers were fooked since I annealed and try to re-use them twice. I'm just being over-cautious now and recommending everyone either buy replacements from Nissan or... measure the ID and buy some off eBay like I did as extra. Also the copper bit that joins one washer to the other (only if you get OEM washers) is bad as if you put on it almost immediately twists where one washer turns upon tightening and the other doesn't. Hence the middle joining bit will pull and distort the other washer and cause a leak :wack:only said that (anneal the old) james as i remember something about someone getting the hoses with the wrong banjos/washers
That's a really good suggestion Trini and one I would have forgotten myself lol :wack: BTW Ross, the drain plug is on the bottom side of the rad so you have to go under the car. There should be a hole in some undertray or plastic section that lets you get a screwdriver to the drain plugYou really need to get underneath the car after a drive and see where the coolant is coming from, it's the only way really. also check the plastic drain screw to the passenger side of the radiator. I have seen in some cases the screw being a little slack and causing a slow leak of coolant. May be worth a try.
