mint
- 18 March 2007
- Age
- 40
- Asakusa, Tokyo
- www.JDMtas.com
Ok.. i dont know what up with the car tbh. I'll explain it the best I can do.
After the previous drift day i was at .. the car hasnt been feeling right since (As to be expected while drifting?)
The Symptoms.
1. Pulling away in 1st is sluggish.. feels like clutch is slipping HOWEVER revs dont really rise, but you do need to put the foot down a bit more to go or it'll judder.
2. Car is down on power IMO. Not so much top end but from the go ahead.
3. Reversing yesterday alot of whinning coming from the rear (Not done this before)
4. In traffic yesterday in first gear start/stop a whine from the rear.
5. On slowing down using the gears, or lifting off the throttle at high speeds in 6th the car tries to 'fish tail' sort to speak.
Think thats it..
The clutch that is fitted for info is a Cusco Copper plate with OEM s14 pressure plate + OEM (original) flywheel with OEM s14 Release bearing. Diff is OEM Helical and the Box is OEM 6 Speed. Iv not changed the oil in the box/diff since buying it. Clutch plate was fitted last year.
Done average hard driving, Daily driving and a good bit of skiddy + ALOT clutch kicking at the drift days.
Also I have noticed the hot pipe side of FMIC pipe (Rubber part) is starting to split as i noticed its resting on the metal of the car and cutting it.. Will be sorting this ASAP!
Any idea's lads?
Thanks
The Symptoms.
Think thats it..
Any idea's lads?
Thanks
