Hub carrier-identical to S14?
mitch
As above really. Is the rear hub carrier the same part number on the S15 and S14? I want to fit a decent handbrake to mine, and I have S14 parts available to build it up off the car and then bolt it on as a unit, saving on down time.
I assume it is, but just in case......
Thanks in advance :)
Do you mean the bearing or knuckle?
Well, both are the same anyway :D
mitch
Knuckle bit, but will probably use the whole part for ease, and keep the S15 bearing/hub as a spare as it's newer.
Thanks mate, I figured you would know :)
