ideal oil pressure bar on gauge
N
neospezi
what is the ideal oil pressure bar when idling after car is warmed up? i recently installed an oil pressure gauge and it reads 1bar only. the irritating part is that theres a beeper that beeps once it hit 1 bar so my gauge keeps beeping when im at a stop at traffic lights. anyone can advise?
11 May 2009
Dominican Republic
I believe 1 bar is the normal oil pressure when the car is warm, mine sits at 14 ~16 psi at idle, which is about 1 bar. You might want to lower the beeper to 10 psi perhaps?
lol my Defi does the same although I've got it set to kPa which I think is the same as bar??
Anyways mine always dips to 0.9 to 1.0 when I lift of to change gear at low speeds or coming to a stop at lights etc. It's really annoying as it beeps all the time if I have it set to 1.0 or higher so I've set mine to 0.8 and it rarely beeps unless the flywheel is being a real pig and revs drop like it's about to stall when I come to a stop grrrr :wack:
24 August 2006
Trinidad
Have yet to install my defis but on the GTT ER34 I had that problem and dropped the warning a tad bit lower and works a charm but still setting the limit to something worth giving a warning.
Darren_S15
Club Event Orgainser
18 January 2008
Essex, UK
One bar is normal for me also, does sometimes dip lower.
Like Lupix I've got mine set to 0.8 and it only beeps when dipping the clutch sometimes.
You must be able to set the beep on yours lower than 1 somehow?
24 August 2006
Trinidad
Yep, that's why you big top dollar for them, better known as an engine-saver.
