JDM S15 Satellite Navigation
K
kazama
Guys,
How do you open the screen above the aircon vents ? :confused:
Tried pressing the OPEN/CLOSE button on the player right beneath the air con,
and all that happens is beep beep !
Tried pushing the screen unit as well, to see if there's a clip but it didnt open.
How do you open it ?
Thanks guys.. :thumbs:
Derek
i wish we knew.. None of us have it!
S15R
make sure ur hand brake is up :D
it doesnt allow you to use while driving
:rotfl:
that sux.
But sure the screen can be activatedn and then you take off? or does the screen go into "hiding mode" when taking off?
S15R
it will close when you put down your hand brake
yes you can disable it.
you will need to modify thw switch under the hand brake
some how my mate modified his and it works :thumbs:
K
kazama
hey there,
how did ya mate modified his to make it activated all the time ?
elizium
Moscow, Russian Federation
www.mys15.org
never had a problem with mine - push open and it opens.. probably somebody rewired mine before I got it...
just wish the thing was in some way useful and I could understand Japanese!!
I imagine you'd need to disconnect the switch and short it. Sounds as though it works in reverse to the handbrake warning light, i.e. as if the light was on all the time.
C
chop sticks
Its the sat nav your talking about right? well it opens when you push the open button on the factory head unit. Otherwise you can connect a seperate switch like i did. I ended up changing the screen to a slave screen so i could watch dvds on it.
K
kazama
thanks for the input guys.. :)
chopsticks, Is that the original screen ? I tried pushing the buttons on the headunit but it wont open.
I'm also thinking of either converting it to sync with a double din dvd player i'm going to buy soon or
convert it to read GPS from those GPS palm thingy as currently the maps for Malaysia havent been made finished. :cry:
cheers fellas ! :wave:
