Knock is at 69
14 May 2011
northamptonshire
hi mate, ive had problems with my knock readings. is that 69 on full throttle?
mine was hitting 82knock on full throttle at 4,700rpm turned out to be a knackered earth on my ignition leads. check everything basic :)
so yours was not knock as in actual knock JIB..... was uncle spoonman onto something ?
2 September 2012
Norwich
That's what I thought as it only hits that high occasionally. Engine management was coming on at 4500rpm but only flickering.
drifter
4 April 2011
Norfolk
If the em light only flickers on and then off again I wouldn't worry too much. If the light stays on flashing then you need to back off :)
