Hey all, been a long time..... now I'm back with some questions if you've got the answers! It's lengthy so please bear with me...
For anyone that already knows me I was an active member for a few years some time ago while I built up my last s15. I put my heart and soul into the car which eventually got sold when we had our little boy and was swiftly turned into a banana by the new owner, never to go back on the road.
Anyway long story short, my boy starts school full time soon, missus will be back out to work and it feels like the time is right to do it again using everything I learned from last time. This time the car will never be sold!!!
Basically I've been out of it a while but I have a clear goal in mind. It will be a second car for street use, aiming for around 400-450hp reliably and after a lot of consideration I will probably go with a 1jz (vvt or non vvt haven't decided yet) with a single topmount setup using either a 350z or BMW transmission depending on what I think of each and how well it suits being driven for pleasure rather than drifted or tracked.
It doesn't make sense to start with a spec r as the intention I'd to tear the car down and build it up from scratch pretty much. Do it once, do it right. So that probably means a basic straight spec s with auto box.
So basically I have a few questions because my memory isn't too great...
Are spec s driveshafts same as s14 turbo models?
Are they 4 stud?
Is the diff a viscous same as s14 turbo models and does it use the same casing (pretty sure it is but doesn't hurt to ask)
Is the bmc smaller on a spec s (intention is 8pots up front and z32 rears)
How much work is needed on the tunnel for a 350 box using an off the shelf mount kit from one of the generic makers?
Has anyone got experience of a 1j and how it fits with the bmc/servo/cmc/rack with top mount and abs pump on the inlet side? I would consider junking the abs if there are no legal things around it.
I realise that the brakes and chassis bracing are different among other things but being essentially the same car I'd much sooner start with an s seeing as a lot of it will be binned anyway....don't see the point in paying the extra for stuff I'm going to remove anyway. I'd be relocating battery and fuse box as well and any other crap out of the bay that isn't needed to make as much room as possible.
I also realise there will be people questioning 1j over rb and it just comes down to the amount spent vs reliable power made. I realise the rb would probably be much easier layout wise but the 1j will give me what I want for the amount I want to spend without the kind of money you have to throw at an Sr etc to get it there and the gearbox problems that come with it.
Budget would be around 15k, 10k for the completed car ready to roll with all new suspension, polybushed, braced, brakes, wheels and tyres, kit and paint etc as I can budget for all that and another 5k with a little leeway for the engine with all work done myself besides paint and setting up. If I can get it done on target it's a bargain as a stock spec r still fetches 10k - that's how I justify it anyway
any other complimentary bits and bobs that aren't essential to getting it going engine wise and tarting up the interior can be added over time but the aim is to get the car how I want it and running well. After that the rest is just icing....
Dean.
Are they 4 stud?
Dean.
