Need an uprated clutch ASAP!!
Y
YazS150
I have rung DB power and Driftworks they dont have them...Driftworks has a conversion flywheel but it can only handle stock clutch. Where can i get one delivered within the week?? Any Comments appreciated guys!!
Y
YazS150
how quick can they get it out to me?? And does this clutch retain standardish pedal pressure?
nearly...
you could get an uprated slave cylinder, that'd help things.
i've ordered parts from perfect run, and they've been with me within a week,... but you have to take into consideration, they're comin' from the other side of the world, so may take a little longer. but, i can pretty much gaurantee you won't get one quicker from anywhere else in the uk.......
sushiming
13 November 2005
Hong Kong
with that clutch the pedal feel about the same as thats the clutch and flywheel which i have fitted...
Hmm. Maybe I'll sell my Nismo cylinder then if it doesn't make much difference.
Yas, getting a new clutch within a week can prove to be difficult.
I just ordered an Ogura Racing clutch 409 kit (same as Sushiming I belieave) from perfectrun and the time for them to get the clutch from ORC was 2 weeks. I made an enquire with GB auto trader about a Nismo clutch first, but that was also two weeks for them to get it.
So your best bet would probobly be to find a place who's got one in stock.
To do that you would probobly need to look at actual tuner-shops in japan as most web-based shops doesn't have a big stock.
I don'e know that many tuner shops who can speak good english with a good stock. You could try Endless-R, GT-Culture or maybe Kanzen performance.
Y
YazS150
OK if I can get one in 2 weeks that is the most I can wait...Cheers for the info guys!! I've got Jez from Horsham on the case as well...hopefully something will turn up soon!!
2 weeks plus delivery from Japan which will be about 4-6 working days.
Y
YazS150
how much is the uprated slave cylinder and where can i get one from?
Are you 100% certain that its the clutch that's gone? From what you described, it could be several things. I'd be inclined to get it properly inspected before (perhaps needlessly) changing it - particularly if it was just a £20 thrust bearing which had gone.
SherlockHomeboy
Try Julian from garage d, he may be able to souce one quicker
mint
18 March 2007
Asakusa, Tokyo
www.JDMtas.com
Little confused..
RPS Max Stage:
http://www.driftworks.com/catalog/p...t-organic-clutch-kit-s13-s14-s15-r32-r33.html
SPEC Stage 2:
http://www.driftworks.com/catalog/products/spec-stage-2-clutch-kit.html
SPEC Stage 3:
http://www.driftworks.com/catalog/products/spec-stage-3-clutch-kit.html
Y
YazS150
APEX PERFORMANCE ARE LEEEEEGGGGGGGEEEEEEEENDS!!!! I dont know y i didnt ring them in the first place!!! RPS Max Street clutch and APex conversion flywheel ON THE WAY!!! WAHOOOOOOO!!!:thumbs:
