need help with these seats
I don't think they will fit stock rails due to size and height. You will probably have to get a universal or S15 rail. Low mount is the best option.
21 February 2012
What exactly you mean by s15 rail is it diff then the one from stock?
Mike
16 May 2010
You'll need different seat rails(bit that attaches to the bottom of the seat and floor of your car!) The holes in the aftermarket seats will be in different location to the standard ones therefore the standard rails will fit only the standard seats.
The seats in the link you would need to find the width and length of the holes on the bottom and then find a s-body(s13/14/15 rails will fit your floor) rail to fit that or modify.
For example I bought my Evo 4 Recaro's for mine and then had to find a set of rails that were able to fit the seats and the car.
31 August 2007
Ashton, Manchester
you should be able to buy the rails from the seat manufacturer or search the net. I got Bride rails for my Gias Low Max.
