New turbo.....help please
N
n6ray
Basically my turbo is dying a loud and smokey death, and basically i'm contemplating getting a bigger turbo rather than just a direct replacement......
My car is pretty standard other than a trust air filter(mushroom sort), a tomei manifold, an apex turbo elbow and de-cat and a cat back blitz nur spec exhaust. It also has a baffled sump, but that shouldn't matter?! oh and the clutch I've got is an exedy organic sports.
The choice is either to replace with a standard gt2560r or get a gt2871r, but if i did go for the bigger turbo what else would i need to do?! and if i just bolted it on a left the car standard would i see much gain?!
Thanks in advance......
23 July 2010
SW London
You'd get away with running a GT2871R on stock injectors but it's almost pointless. It's a physically larger turbo in every way, so there will be gains but very minimal on standard boost pressure.
Put it this was, if you want to run a larger turbo, the costs don't stop once you've bought the turbo...
13 November 2006
Swindon, UK
+1 to what Adam said. To make the most of the bigger turbo you'd need
Remapped ECU
Bigger injectors.
Z32 MAF
MHG
That's just for starters. :)
Metal Head Gasket
sx-si
7 June 2008
hampshire uk
why does he need a headgasket on a 71r?
unless your screaming the living death out of a 2871r and pushing for 400 then maybe
but just running around 1.2 bar on a 71r then you shouldnt need one at all
also your missing a fuel pump
and a front mounted intercooler
then you shouls see a minimum of 320 at 1.2bar
13 July 2010
Brighton-UK
BorgWarner EFR range nice, completely re written the rule book on turbos with integral BOV and other goodies, would like to see one of these on a 15.
Just to add to sx-si list, also need an FPR and a good idea to go with a new set of braided lines for the turbo.
Now the £££ start to add up.
If you want to keep the car lightly modified then I would consider a GT2860R/GT28RS. Its a good upgrade from the stock turbo if you don't want to change cams,injectors AFM etc.
