Nissan SR20DET Starter
10 August 2018
Brunei Darussalam
Hello everyone, my car is Nissan Silvia Spec R Turbo S15. It was original come with 4 speed automatic transmission but it was converted to 5 speed manual from Silvia S14a.
My car starter now worn out so the question here is i need to use starter from S14 or S15?
Thanks everyone.
willy s15
25 January 2014
greece athens
hey mate if u with s14 trans is together starter as auto and 6 speed is tottaly different
go for s14
10 August 2018
Brunei Darussalam
go for s14
I dont know if they change starter during manual conversion or not so i need to use s14 starter since my transmission is from s14?
Thanks
immy21
9 November 2012
Edinburgh
I don't know if it helps but I have an S14 starter fitted to my S15 Spec R, the starters are a little different but interchangeable.
10 August 2018
Brunei Darussalam
Is it s15 Spec R auto or manual 6 speed? If not wrong S15 6 speed flywheel is different than S14 5 speed manual.
Joeh
12 December 2006
London
www.silivaoc.com
@silviaownersclub
If the flywheel is from the S14 then an S14 starter will work, have you thought about getting a used one from eBay? There are many kicking around
10 August 2018
Brunei Darussalam
Yes i'm using S14 flywheel and clutch kit
I'm getting from local shop selling used parts from japan, they have both s14 and s15
10 August 2018
Brunei Darussalam
Just found out today starter on my car is 23300-80F00 is it S15 or S14?
And is it interchangeble with 23300-52F10?
