hey people,
just fitted my oil temp and pressure gauge sender units yesterday and wanted to check what i should be expecting to see with you guys.....
on startup (fast idle) the oil pressure shows up at around 80psi constant, then as the engine warms through it drops to around a very minimum 20psi constant at idle when warm. when driving the pressure rises with the revs and peaks at between 80-90psi and when flat out sits up there perfectly steady, i dont get any fluctuation or hunting at all at any revs or on idle.
as for oil temp, what would you guys class as warmed up? didn't get mine to go up much past 75'c but wasnt caning the hell out of it (kept stopping to check for leaks from sandwich plate).
any info appreciated
