REmoving boost controller??
jonny b
if i remove my electronis boost controller,as in disconnect all the pipes going into the back of it and the unit in the engine bay,will the boost stay as it was set before it was removed??
nope - theres no form of boost control then other than whatever the actuator is set to and the boost the engine is producing naturally according to the mods. also you'd need to re-fit the standard boost solenoid i believe to get it to work properly/safely.
jonny b
cheers mate
