ok the engine from my s15 is up for sale as i've changed direction with the project
the engine was rebuilt before the car was imported by garage34 in japan i have done since around 2000miles
spec reads
lightened and balanced crank
match weight rods and pistons
nissan bearing
nissan rings
nissan oil pump
nissan water pump
ported and polished head
cut valve seats
nagoya uprated valve spring
tomei 256 inlet and exhaust cams
if anyone knows the car it was in its a very fast set up will do 400bhp all day long and not miss a beat
just bear engine block with front pulley i'm looking £1600
i also have the atc inlet for sale separately and hpi nismo 6 speed box not cheap tho
thanks
spec reads
nissan bearing
nissan rings
nissan oil pump
nissan water pump
cut valve seats
thanks
