S15 Fuel Filter Part Number? (is it the same as an S14?)
18 September 2011
West Midlands, England
Want to replace my fuel filter today to eliminate it as a fault on my hesitation problem.
does anyone have the part number? or know if its the same as the s14 one? as my local motorfactors have an s14 one in stock
What power/boost are you running?
If you're on the standard turbo, just go for the normal one. Same as S14.
18 September 2011
Thanks mate, i'll go grab it now, see if it helps!
Yes it's the standard turbo, standard boost. Only mods are FMIC, apexi filter, cat back exhaust (soon to have decat). i WILL be upping the boost when i get a boost controller.
Craig, while im there i'll get some plugs for it to. with my spec, what model plugs should i run?
I'd go for NGK BKR7EIX Iridum plugs as they will be fine and last a fair while.
Copper plugs are good too but you have to change them quite often and you'd have no benefit this level.
You may have to get them from eBay or similar though as your average motorfactors probably won't stock them.
Link
