- 14 November 2005
- Scotland
- www.s15oc.com
Further to this thread: - http://forum.s15oc.com/viewtopic.php?t=494
I did some digging into the S15 Helical diff, as you can see from a recent Drift Uk event i attended (link above), the diff would apear to be not working correctly, only spinning up the inside wheels. However, this is what its meant to do. I will let someone who knows what there talking about explain -
Barky @ Driftworks said:The picture does show up that one wheel is clearly spinning up.
First of all the S15 diff is very poor for drifting as it never actually locks up both wheels. Just because one wheel is spinning doesn't mean the diff is broken. What you have to think about when we talk about limited slip diffs is, it is called a limited slip diff because it limits the amount of slip between each wheel but eventually it will allow slippage. An open diff has 100% slip i.e. it never locks up. If we just consider an open diff, its job is to allow one wheel to spin faster than the other during cornering / turning. When you accelerate hard enough on an open diff during cornering the inside wheel will always be least loaded due to the weight being transferred to the outer wheels due to the centrifugal forces of the vehicle. The inside wheel will lose grip easier and when it does all the power gets transmitted through this wheel as it has the lease grip, hence the one wheel spinning. With all diffs there is a certain percentage of slip, i.e. open diff has 100% slip, a viscous diff may have 75% slip therefore 25% lock, a clutch drift diff may have 30% slip and 70% lock. The percentage relates to a breaking away torque i.e. the amount of torque the diff transfers to both wheel before the diff begins to slip each wheel.
Helicals never lock up as the power is constantly varied between each wheel, but at the same time some slippage occurs and one wheel will always spin once the breakaway threashold is met
