S15 speed sensor
peteman35
HI guys ive tried searching but cant get a solid answer.
I have a Spec S converted to SR20DET, it has an open diff.
I have a s14 diff but someone has cut the wires off, which one is the speed sensor? Theres 2 on the backing plates and one up by where the prop shaft goes.
Obviously i can just steal the bits off the Spec S diff when i take it out. but i dont want to have to take all 3 sensors out if i dont need too.
Thanks
Have a look in the manual at the brake section page BR-87. It doesn't really give a good view, but it may help.
drifter
4 April 2011
Norfolk
Speed sensor is the one near the prop connection :)
24 January 2013
Kent
Speed sensors on the s14's are on the gearbox not the diff so I doubt you could fit the sensor to the diff?
drifter
4 April 2011
Norfolk
S15 uses the the abs sensor for speed, you just need to fit you s15 abs sensor into the s14 diff. If the sensor was intact you could use it, shame someone has cut the cable as the sensors are an arse to get out without breaking them.
Kev
28 February 2011
andover, hants
Ive got a s14 abs diff in my s15 and it all plugged in and worked fine! No changing any sensors so give it a go mate
16 August 2013
W.Mids
If you go from the 4.08 to 3.69 ratio though then your speedo reading will be miles out, no?
Kev
28 February 2011
andover, hants
I'm not sure? I had a auto diff and have put a manual welded 14 diff in mine and the satnav still confirms the same speed as the speedo! I think its just different gearing! acceleration ect...
drifter
4 April 2011
Norfolk
I've got a 4.08 diff in mine an the speedo is okay :) I kept my old speedo converter as I expected it to be wrong, but never needed it
