- 17 January 2012
- Essex
- @kwalker88
may as well stick a project thread up for this as i plan to make several changes, both small and large
Bit of history, bought the car on Tuesday from SVA in Dover. Quite a nice spec all ready, suspect it was a drifter in Japan as it seems to have had some decent parts on it. SVA seems to have removed most the good bits though including a z32 maf and we suspect they removed a aftermarket ECU which is a pain as i plan to fit one.
Anyway current spec :
Body:
Aero body kit (this is what is listed as but i don't think it is?)
FRP vented bonnet with pins
Possible ADVAN? 17" alloys with ****e tyres.
Engine:
Uprated front mounted inter cooler with hard pipe kit
Koyo Rad
HKS filter
Blitz nur spec exhaust
Heat wrapped tubular manifold
Downpipe
silicone hoses
oil catch tank
Chassis/drivetrain:
Cusco 2 way LSD
Fully adjustable coil-over suspension
Cusco strut brace
Interior:
Nardi steering wheel
Picture after i got her the 80miles home on Tuesday.
First things first i gave her a good going over with a machin polisher on the Wednesday, Use a cutting polish, followed by poor boys white diamond and then a layer of wax. paints in pretty good condition so pleased with how it came out
Took her to work yesterday and broke down on the way in. One of the coils gave up so a trip to Dover after my night shift and i came home with a fresh one. Problem solved.
Also fitted a snap off boss (no pictures) for a bit of security and have someone coming round on wednesday to fit a clifford 650 to it.
The passenger headlight has some condensation in it so need to whip that off and give it some new sealant and i plan to coat the centre console in vinyl as its looking a bit ropey
Will be buying a new set of blue wheel nuts tomorrow as the ones on it are very worn and a new set of bonnet catches as the silver ones look slightly tatty.
Future plans are to stick a small set of spacers on to get the wheels sitting slightly better untill i can afford a set of Rota Grids. Pick up some gauges, Boost, oil pressure and water temp. (looks like the fittings for the water temp gauge are all ready in place) Set of bucket seats, harness and possibly a cage. Also looking at a link ECU and z32 maf for some more power.
Immediate plans are just to enjoy it and hope it doesn't go wrong again!
Body:
Engine:
Koyo Rad
HKS filter
Downpipe
silicone hoses
oil catch tank
Chassis/drivetrain:
Cusco 2 way LSD
Cusco strut brace
Interior:
