My rocker arm stoppers from Tomei arrived today, according to the installation instruction that come with them, they say to torque to 11.8Nm the cam nuts, at this low setting i discovered the hard way to make sure the wrench does not move higher then this setting, which happened just by handling it.. One of the bolts snapped on me.
Has this happened to anyone before?
were you able to get the broken bolt out or did you have to drill and tap a new one.
I have now removed all the bolts holding the intake caps on, the FSM says to tighten in a specific order which is all good, but the cam is sitting up at the back by about 2mm, is this normal due to the weight of the cam gear and chain?
