Turbo wastegate actuator arm problem, it looks bent!
Hi guys I took my manifold heatshield off today as it was rattling! And ummm my wastegate actuator arm looks bent and the turbo butterfly swivel arm looks welded onto the housing. It can't be like this right.
Here are some pics with crappy phone.
I can adjust the boost and it boosts well but why would this be done?????
If there is a blob of weld then the previous owner of the car or turbo must of run an external wastegate - the pics are pretty rubbish to be honest mate, got any more? T28 actuator arms have got a controlled bend in them as standard btw ;)
Ok better pics! First pic is the weld and second/third is the bend
This is the actuator
That could just be the sleeve where it's tacked to the housing, the spindle is inside it. The arm should be like that...
Joeh
12 December 2006
London
www.silivaoc.com
@silviaownersclub
When the car is cold - try to open the butterfly with your hand by moving the actuator arm - if it has enough movement - around 1.5-2cm then it should be fine - if its stuck solid then its questionable.
Joeh
Dean you are right!! Phew! Thanks guys, it moved a centermetre or so! Being new to sr20's it's hard to know what's what. Thanks again. Matter CLOSED!
24 November 2009
North Yorkshire
I like to have input. So heres mine. I've got my turbo on the floor next to me, and mine is exactly the same as yours. its all good mate :)
Yep,that weld is just a tack weld to hold the sleeve for the arm to go through.
Lol thanks jaseYpk!!! :) it just didnt look right to me! But tis all good now!!
martinbattye
thats all 100% stock,, at ease!
