Walbro
130r
Have been seraching for a Walbro GS-341 fuel pump and unfortunately not been successful, only GS-342 is available.
The look identical but the position of the socket bracket and the output pipe is directly opposite of the GS-341.
This GS-341
GS-342 see the different in position between the output pipe and socket for the 2.
Any advise
These are the ones we can get fairly easily over here:
As you can see they're 342s. If you're worried about the 342 fitting - don't be. It'll fit with very little adjustment.
Here's the standard pump next to the 342:
As you can, see the two pumps are so similar that I'd be temped to say they were the same manufacturer...
