winter clutch problems
djmasterg
Hello
Again - I am very suprised how good s15 was - until today. I started engine, heat it up to normal 90 degrees, drove about 5 miles (clutch still working) but then it started to fade away, untill its totally gone. So I drove back to my flat on 4th gear and parked it. Now, when I press the clutch pedal there is no reaction. Is it because of the frost? My car was sitting without moving for about 10 days untill today. What should I search for to fix it?
Happy new year
Greg.
Have you checked your slave cylinder for fluid or leaks and your clutch cylinder on the gear box?
djmasterg
Hi
By "there is no reaction" I meant that when I press clutch pedal to change gear - it doesn't work - so maybe simpler - there is no clutch. I was stuck in 4th yesterday and when I tried to engage 1st when I stopped - I couldnt. So it seemed like clutch failure. But I checked clutch fluid and a big supprise :) cylinder was empty. So next thing I will do is to buy some fluid, fill it up, and check where it leaks.
Will let you know.
Greg.
djmasterg
Hello again
I have taken a picture of a leak - its a pipe (metal one), it has some kind of loop on it, leak is just before this loop, please look at this picture:
This picture was taken from passanger side, front of the car is on the left. Could you tell me if this part number is 30650+B (nissan FAST)?
Thanks, Greg.
You can actually do away with that pipe and with a bit of re-routing fix the pipe coming from your slave cylinder to your clutch cylinder.:thumbs:
Its just extra piping from Nissan to make the clutch feel nice and light.
I removed mine and straight away got better peddle feel. :nod:
djmasterg
Hi
I already ordered a braided pipe from db-power. Only thing is to wait untill it arrives and put it instead of this faulty one. Thanks for advice.
Greg.
djmasterg
HI
post arrived, got this from db-power:
But it doesnt fit instead this metal line - both ends of original metal part can be undone with spanner size 17. This new one has smaller spanner sizes on both ends (11 and 14 mm).
to Auss15: I would like to know how exactly did you fix yours. could you post some photos?
I am really confused - my lack of mechanical knowledge plays a big part - thats why I ask for some solutions.
With regards
Greg.
Thats me again!!! I looked for a service manual, found it and did what you told me before. I admit I was a bit stupid but now I am going to get her back on the street - clutch is working again!!! Thank you guys, sorry for my silly questions.
