De-kitty kat
S15 SILVIA
Hi all.
Looking to buy a decat, am I right in thinking this will fit?
http://www.ebay.co.uk/itm/160451115143?redirect=mobile
What you think it looks like? Quality looks good for the money?
Otherwise should I just get the s13 one from apex?
Only ask, as this looks tidy for the money?
Any Benefit from having a decat with a chamber?
Thanks Mike
not sure on fitment for that auction, but i would just get a made up peice put in thats exactly the size pipe you want and will fit perfectly from mild steel, probable be cheaper then that de-cat
S15 SILVIA
I know what your saying, but I don't have the facilities to knock one up.
Wanted to buy one, so I can just bolt it on when I get to go under the car.
Just wanted an opinion on the one mentioned, and to make sure it would fit.
Cheers anyway.
S13 315mm 3" decat is a direct fit mate ;)
S15 SILVIA
Cheers Dean.
That was the answer i was looking for!
Any idea if there is any advantage to having a chamber?
If anything, i thought it may pass as looking like a sports cat when it comes to the mot.
Do you have to change your cat come mot time?
Cheers Mike
I do mate... It would be great if I didn't have to but my mot guy is a good bloke and if the ministry saw me drive out without a cat and with a fresh mot he would be well in the brown stuff, I'd never expect it for the sake of half an hour spannering swapping them ;) as for the chamber type... I don't understand the benefit tbh... The rest of the system will be 3 inch so it won't really improve flow and if anything it will make more noise and give less ground clearance but I don't have personal experince of that. I'm currently looking into getting quality decat silencers for our cars, made to the s13 pattern in all stainless. I started out to make one for myself but if it works out to a reasonable price then I'll see if others fancy one, it's literally the cost of a quality 3inch silencer, 2x stainless flanges and the cost of tig welding so I'm expecting it to work out at about 120-130.00 which is cheaper than apex sell s14 ones for...
als_jordan
13 July 2007
Dean, let me know if you do do this, as I would be interested assuming it didn't affect ground clearance much.... Thanks!
Will do mate ;) the diameter of the silencer is 125mm so no less ground clearance than the standard cat :)
E
empty_inside
I'd be interested in one of these too, assuming it will make a big difference to the noise. De-cat is sooo noisy!
24 November 2009
North Yorkshire
i cant believe how much these decats are! i got mine from Japspeed for about £50!
but they have since removed the item off their website :s
might be worth a call to them to ask if they still do them?
Well the one I have is ready to be made up, just need to check how much welding is...
S15 SILVIA
I actually ended up buying one of the eBay ones I listed.
Not fitted it yet, but seems really good quality. Welds are neat, has nice thick stainless flanges, and should have no clearance issues!
Will post a pic once fitted.
Keep us updated on your boxes tho Dean, as I may be interested too. :)
