Well registering went smoothly and shes fully road legal now.
Dirty Stop Out. Filthy after it's First night out on UK Roads.
Some TOUGE ACTION
Now it was still throwing a code 34 - knock sensor, so after looking at the possible causes, and eliminating a few, including changing the knock sensor itself, i changed the coilpacks.
OEM items were coming up pretty pricey, and wherever possible i like to upgrade instead of simply replace, so i went for those blue tops :thumbs:
Splitfire DIS-007's
After a week wait, and a hefty £50 import fee, they were here. I hastily got to fitting them and to my disappointment it didn't cure the fault :down:
Having a rare free day i could spend on her, i decided to crack on. I traced the knock sensor loom back, which turned out to be only 8-9 inches long! removed it for inspection.
This is what i found!
Looks like the loom was the problem all along
in the process of getting hold of one now, and hopefully that will be the end of that
did some general maintenance:
Oil Change with MOTUL 5W/40
Replaced the o2 Sensor with genuine Bosch unit
was made unbelievably easy with this - Neilsen O2 sensor socket
decided to fit my Broadway i had
Updates coming soon:
With the knock sensor fault keeping me from progressing the car in other areas, now that (fingers crossed) it is sorted i can get to work.
Time to up-rate the Brakes all round. Lined up a set of K-Sport 8-pot 330mm for the front, but still undecided as what to do with the rear. Tempted to go with the Z32/R33 conversion but for now i think go with up-rated discs & pads with the oem calipers
Few days off next week before Japfest which i'll hopefully get down to, so i will spend the time tucking the loom up in to the arch, and wind down the coilovers to get it sitting nicely
