JP825
Has anybody tried to take the passenger airbag lid out? Tried to take the dash out there but dont want to set off the airbag.
Does it just pop out?
Thats sounds so cool, so you going to remove the air bad totally and replace it with the gauges.Yes disconnect the battery, remove the glovebox and underneath there you will see a couple of nuts that need removing, I tihnk four in all, once removed and the air bad wiring clip unplugged the air bag should just pop right out. I actually removed mine two weeks ago and I and going to remove the skin from the air bag unit and replace it with a custom gauge setup that will once the accessory switch is engaged will swing open via an actuator and display the gauges underneath the airbag, three Defi gauges.
let us have a look now!Yes disconnect the battery, remove the glovebox and underneath there you will see a couple of nuts that need removing, I tihnk four in all, once removed and the air bad wiring clip unplugged the air bag should just pop right out. I actually removed mine two weeks ago and I and going to remove the skin from the air bag unit and replace it with a custom gauge setup that will once the accessory switch is engaged will swing open via an actuator and display the gauges underneath the airbag, three Defi gauges.
