Fuel Pump Install
superbike81
Getting ready to install a Walbro 255 fuel pump. Was looking at the fuel pump cover last night in the car and there are wiring connectors going into the top. Which one will I splice the fuel pump wiring into? Why are there two connectors? I'm not used to seeing this, every other car I've done a fuel pump on has just had one.
Thanks for the help!
if you're fitting a walbro pump then dont worry there is no splicing to be done. the standard plug on the original pump plugs into the walbro without any modding.:)
May I suggest you read the guide on my site before doing anything? Most of those connections on the top are fuel lines.... A Walbro is nearly entirely plug and play on the S15 (its not on the S14).
ah was on you page and only went through your s15 guide. very very helpful page that .
so stick with your existing fuel filter if its in good nick ? and is a fuel regulator needed with fitting this ??
Nope. :)
I don't really agree with FPRs. If you need more fuel, fit bigger injectors ;)
so just the pump is all i really need as my motor i reckon is unmollested except for a metal head.
thanks buddy.
